Vacuum line to regulator boots
Replaced the little rubber boots making the connections. They need to be a tight seal. If they are hard/brittle or soft/expanded that'll cause this issue. I just went through the same problems. I didn't realize this was my problem till I heard the boot connecting the FP regulator leaking after it warmed up. I've never seen one expand that much from being warm, it was fine when I connected it cold, but after a warm up, it grew larger and quit sealing. They're cheap and if it's not the problem, you saved yourself some headaches down the road.
You're #4 post I've read today with similar issues, it's still fresh in my mind.
