4WDriver
- December 3, 2008
- Las Cruces, NM
- '02 Explorer XLT
Hey all,
I've had my '02 Explorer since April of '08 and love almost everything about it. The one major problem I have with it is the lack of suspension flex it has for off-road stability. I have tried removing the sway-bar end links on the front which helped, although the results are still below what I expected out of it. I traded-in my '96 Jeep Grand Cherokee for the Explorer and was used to the way the Jeep would flex. My last hunting trip I went down a stair-step obstacle which was relatively easy and not huge drops by any means. When I returned to go back out, the Explorer would get past the first step with the front wheels, but once the rear got to the first step and the front on the second, it would lift enough weight off one wheel both front and back and just spin them
. I ended up having to tackle the relatively mild obstacle with more momentum than I cared for which caused me to hit the front crossmember on said obstacle
, though I made it up. This wasn't damaging to the vehicle, but I don't want to have to force it up such easy obstacles. Is there anything I can do to get better flex for increased traction and stabilty off-road? Aftermarket struts? coil-overs? Thanks in advance for any suggestions you may have.
Sincerely,
Jose
p.s.
I almost rolled the Exp on another easy obstacle due to lack of flex. It was an off-camber descent which had it teetering on the passenger front and Driver rear wheels because they wouldn't stuff into the wheel-wells.
Sincerely,
Jose
p.s.
