dave8351
- January 12, 2014
- 1992 Ford Explorer Sport
For the past few months I've been having a fairly regular problem with my transmission. When cruising around 30 to 45 mph the transmission seems to shift up a gear too high and the motor lugs. If I come to a hill or want to speed up and I give it gas it downshifts sometimes and then upshifts too early and bounces back and forth. Other times it stays locked in gear and won't downshift unless I really stomp on the gas. When it's lugging if I take my foot off the gas or brake the transmission stays locked in gear. If I brake to slow down/stop it almost stalls and then there's a clunk or bang and it shifts down. Sometimes I can catch it before it stalls and shift it into 2nd and it unlocks, other times I can't and it stalls out. And some times it works fine (not that often).
When I accelerate it usually has no problems, but sometimes I get upshift/downshift bounce for awhile around 35-45mph and occasionally at 50-60mph and is fine at speeds above 65.
I can start it in 1st and shift into 2nd and it runs with no problems until I put it in D or OD.
I have checked the vacuum lines, replaced the vacuum modulator, have no fluid leaks, replaced the TCC solenoid, 3-4 shift solenoid, replaced the TPS, replaced the VSS, adjusted the kick-down cable, adjusted the shift cable, adjusted the bands, no idiot lights, and seems to be independent of temperature - happens when the transmission is hot, cold, whatever.
I posted in another section of the forums & the governor could be causing some of these problems & is next on my list to work on. Can I drop the transfer case without draining it?
Could it be anything else? Any ideas/help with what's going wrong would be greatly appreciated!
