wooky
- October 1, 2005
- Southport nc
- 2000 Sport
Ok guys I need some serious help here. I have searched the forums and found alot of info but hoping to get some more on this thread. Heres the deal; I have a 2000 X sport with V6 SOHC 71,500. miles. Since it has gotten cold the idle is horrible(but only when its cold). I changed the IAC and put new set of plugs (not wires) on it. I went to Advance Auto and had the codes read.
DTC (codes)
P1506-P0301-P0171 and P0174
DTC Pending (codes)
P0302-P0303-P0304-P0305 and P0306
The guy said that the pending codes should go away since i replaced the plugs. I guess my ? is; The first code P1506(Idle speed control) could it be makeing the rest of the codes? What I mean is would it be like a trickle effect. I use to build Transmissions for CAT and if we had a bunch of failures on the test stand then we would go back to the first one(failure) and that would usually fix other ones. The P0171 and P0174 codes are both banks reading lean, he suggest that i change the fuel filter. Could this be causing the horrible idle when cold? I also took the MAF sensor off and cleaned it, didnt seem to help it. When it was cold and idleing bad i unhooked the MAF sensor and it idled good. Im kinda wondering if the MAF is bad. Is there a way to check it? That thing cost 130.00 and I dont want to buy it if thats not what is wrong with it. I already paid 85.00 for the IAC and that didnt fix it. Any help would be greatly appreciated. Thanks guys
DTC (codes)
DTC Pending (codes)
