koda2000
- September 2, 2011
- x
There is very little if any clearance between my cross-pin and the axles. I had to use a plastic hammer to drive the pin in, but it did not require excessive force. I could almost push it in with my fingers. There is a "C" eliminator kit according to what I saw on the Summit Racing site, but it's rather expensive and I don't want to spend any more money on this vehicle than necessary.
I considered how the axle button might have been separated from the axle and came to the conclusion that for the most part the axle and pin rotate together (except while cornering). Examining the broken the button and axle end at the break I don't see any evidence that the button was twisted off. At the time it failed I'd only driven about a mile from my house (probably a less) so I don't think any thermal expansion occurred during that short trip. I also saw no sign of damage/wear on the pin's surface where the axles contact it. The button was not "milled" by the "C" clip in any way.
Not knowing what caused the break is what's so disconcerting.
