UrbanXplorerTrek
- October 23, 2024
- North Bend, OR
- 2003 Ford Explorer XLT
Hello.
I just finished redoing the entire timing chain set on a 4.0L. Startup and still heard chain noise, so I tore it down again and fixed the front hydraulic tension by blowing out the oil channel, which resolved that. Then, I noticed a lifter noise, so I replaced the lifters on the driver's side. No more noise, and it idles well, but there's a jerky spot around 1000 RPM before smoothing out again.
I replaced the fuel filter, which helped but didn’t fully fix the issue. Transmission fluid level is good. The compression is good across all cylinders. Also replaced the blown cat, but now the driver's side is glowing red hot shortly after starting. I used the OTC 6488 tool set for the timing, which was checked and confirmed twice. The car ran fine (except for the noise) before the chain replacement. No check engine lights. Any ideas on what could be causing this? The car is clean and is rust free. I don't really want to get rid of it if possible.
What's been done:
- Complete timing chain set
- Front hydraulic tension oil channel
- Lifters (driver's side)
- Fuel filter
- hydraulic tension (Front & Back)
- Catalytic converter (driver's side)
- Fuel injectors (cleaned and checked spray)
- All O2 sensors
- Spark plugs
- Water pump
- Oil pump
- Intake manifold gasket
- Ignition Coil
- New battery
I'm new to the forum, so let me know if you need further information. Thanks!
What's been done:
- Fuel filter
- All O2 sensors
- Spark plugs
- Water pump
- Oil pump
- Ignition Coil
- New battery
