Very curious to hear more about the possibility to activate global open for the windows. Am I understanding properly that since all of the switches aren't auto open/close, that global open is a non-starter? Even having the front windows open from the remote would be a huge help on searing hot days.
Sorry for the turn from the purpose of the thread, but could a dealer turn global open on via IDS instead of using the Forscan app?
I have to see what the wiring looks like for a car with this feature before I can determine if it is possible or not.
Right now I know the system itself as it sits, cannot do it. There are no signal wires present to control the windows besides the operator pressing the switch buttons.
If it was wired I think only the front two can do the operation because of the auto up/down. When the window becomes fully open or closed there is a surge/spike in the current for the motor and these "smart" motors detect this and turn the current off to stop it.
Again I saw a test wire in the wiring so this maybe a control/signal wire that might be used. Look at pin 6 on the front wiper motors.
http://www.revbase.com/BBBMotor/Wd/DownloadPdf?id=875002
As far as straying from the original topic, this is kinda the talk I wanted initiated. Essentially adding OEM options or settings that didn't come with your vehicle from the factory.
This was a big thing on Rangers and Explorers of the past. Ranger guys added Explorer overhead consoles w/ Temp display and Compass, Sport Trac white faced gauge, and even the EATC from Limited/Eddie Bauer Explorers.
Explorer guys added EATC and Message Centers.
My Ranger I added tilt steering column, cruise control, power windows, locks, and mirrors.
Only difference is back on those modules you didn't have CAN bus and most signals were sent by either an analogy voltage signal (ON, OFF, or sensor voltage) or PWM (like speed signal). Then you only had to swap hardware over. Sometimes just having to change a module out.
Now you have to worry about flashing or coding control units and this is what this thread is about.
