Somebody KILL ME!
I thought that turning the bolt around would solve all problems. I was suspect of one problem, and for good reason. With it turned around (i.e. inserted from the rear - no rude comments
, I can't get a socket wrench on it. The socket will go on, but not the wrench, and even if it would, I would not be able to remove it once the end of the bolt was sticking out, and I'd prefer my socket and driver not be a permanent fixture when I'm done.
So, how to solve this? A 7/8" open-end wrench would be a pain in the @ss, if I had one, and I would not be able to torque it. Remember, the bolt does not turn, only the nut. Guess I could hunt down a 7/8" open-end wrench, and just crank as tight as possible. Then it's up to the alignment shop to worry about it.
Even putting it back the way it was would be nearly impossible, given the way I had everything torqued just so to remove it. It would be easier with the replacement bolt, since the adjuster is not welded to the end of the bolt, but that fat steel line is in the way. What the heck is that stupid thing anyway?! :fire:
Maybe if I had pissed and moaned through the driver side first, I would be siting here now saying how easy it was to finish, since the passenger side is so much easier.
Oh, and if I don't finish tonight, it's going to be 100 degrees tomorrow. Well, actually, it's going to be 100 degrees regardless, but if I get it done tonight, I won't care.
OK, done venting for now. Back to the garage to curse some more.
