Hopefully I can shed some light on this.
First, there is only one header that will work on the Explorer V8. It is the E50/E51. These "headers" have the same basic tube design as the factory, only bigger tubes and cleaner bends. Quite an improvement over factory - but far from ideal
Second the P-50/P51 headers WILL NOT WORK. I have trial fitted the mustang style headers on the frame in my garage and they hit the rear a-arm mount and frame.
Third, I have never heard or a JBA header fitting an Explorer V8. I will call them tomorrow, as if it will with simple mods, it will save me one hell of a head ache.
Fourth, the Ranger V8 swap headers will not work either. Those headers are made for the 1997 and older Ranger with the Twin Traction Beam front suspension. Neither the mounts nor the headers will work. The frames are totally different. Different mount location and angle.
OK, now that we have that cleared up, I wanted to let you know why I say these things. I am currently modifying a Kenne Bell 1.5L blower package to fit on the Explorer V8 I have in my 1999 Ranger 4x4. For this engine, I will also have TFS Twisted Wedge heads, 75mm TB, 90mm Lightning MAF, and F150 truck (~TFS) lower manifold.
So, I will need a really good flowing exhaust to get the HP numbers I expect. I have looked at all factotry headers and found none that will fit due to either the frame layout, front driveshaft location, or the huge engine mount plates the Explorer uses.
The next step, which I have taken is to build my own long tube headers. I have managed to put together a complete "buck" in my garage, which consists of the front half of a 1997 Explorer V8, including front axle, steering rack, engine, trans, etc.. I will use this to build the 1 3/4" long tube headers following roughly the same routing as factory, picking up one set of 2.5" cats at the stock second cat location and then finally connecting back up with my current single 3.5" exhaust system.
To anyone who is interested, I have found a place which will custom mandrel bend stainless pipe to my mocked up headers. I plan to build my mock up from a couple sets of mustang headers by cutting and welding the bends. Once complete, I will have them made in one piece stainless tubes and then I will tig weld them together. They will have the CAD/CAM program to bend more sets, so contact me if you are interested. These will not be cheap though, probably in the $1000/set range.
Todd
tmsoko@comcast.net
