bradz71
- October 30, 2005
- Dixon, IL
- 1991 Eddie Bauer
Hey guys, new to the site just figured I'd let you guys know where at I'm with my projects.
I plan on swapping out the 4.0 and the axles that I have in my Expolrer into my 88 BII with a 4'' lift and 31's.. for now. I plan on getting 35's, and I have 4.10's waiting to be installed. But heres my problems:
4.0:
I had it started and running fine. Then I pulled it into the shop to change the oil, and now I can't get any spark. I've checked all the fuses, fuel pump inertia switch, fuel filter, shot ether in to the throttle body, and could not get it to fire. It would crank all day, but not fire. What am I missing?
Trans:
The guy that I bought it from said the trans was shot, but I just dumped two quarts of fluid in and drove it around the yard. 1st and 2nd worked fine, but drive and overdrive did not. So I dropped the pan and the fluid was pretty much black, and had some small shavings on the bottom of the pan. I was hoping that a good fluid flush would solve its problems. What do you guys think?
Here's some pics of my Explorer and BII
4.0:
Trans:
