js8330
- February 23, 2025
- Key largo Florida
- 1999 moutaineer 5.0
Whats up everyone. Names jeff. In the florida keys. I picked up a 99 mounty last year. Its a 5.0 awd truck. Its been amazing. Makes frequent trips from the keys to miami. And it made the drive all the way back from NY state. Anyway, im starting to have trouble with the awd setup. It was popping and the front tires were locking up on me, so i took out the front driveshaft and that was eliminated but the slight grinding still remains. Almost like a bad wheel bearing but i just did the pass and the sound doesnt unload when you turn. Side bearing and half shaft, drivers side bearing is eh i dunno no movementin the wheel and no noises when spinning it by hand. . Gotta check it. But it sounds like its under the truck. Right under where im sitting. Which makes me think T.C or front diff. I checked the oil in there (front diff) amd it was really low so i added some to fill. Also, the joint where the cv axle goes in seems to have excessive backlash. I mean like a half in or more. Is there a pin point dead on way to properly diagnose these so that i dont immediately and impulsively blow my money on a differential? Im thinking its cheap enough ill do the other wheel bearing. Then ill check the backsides of the rotors and see if my ball joints are causing the slight grinding noise i hear. I can get a diff for under 200 and it probably wouldnt he a bad thing to have one on hand.
