RickMar
- April 11, 2009
- N. Andover Massachusetts
- 99 Mercury Mountaineer
Hi,
Thank you for taking the time to read this post.
I have a 1999 Mountaineer 5.0L in need of a camshaft position sensor change.
I found a 99 Mounty w/5.0L engine sitting in a local junk yard. I removed the coil packs and any other items in the way to get a clear shot at the
(1) 13mm bolt which held the sensor in place and down.
After an hour trying everything under the sun to pry it up and out, it would not budge.
If you are familiar with the camshaft position sensors removal could you fill me in on how I can get it out? Is there another lock down bolt I missed or can not see? Pull it up with a slap hammer?
Any information will be very much appreciated.
Thank you,
Rick
Thank you,
Rick
