ewillis
- September 20, 2008
- SC Lowcountry
- 2005 XLT
It looks like there are some knowledgable Ford guys here................I hope so!
I have been having an issue with the P0171/P0174 codes for a while now. I started trying to resolve this before the summer but got too busy and left it. Now the wife is back at work (school) and driving the sport trac daily again. Hers is a 2003 Sport Trac XLT, Non-Flex Fuel.
Codes popped-up right before it was due for oil/ oil filter/ air filter/ fuel filter change. I thought this work would fix problem but didn't. On another forum I was told the problem was DPFE. Spent $125 and still not fixed. I grabbed a can of carb cleaner and sprayed all around the intake and vacuum lines I could find but did not find any noticable vacuum leak. I checked the fuel pressure and have 66 PSI with no fluctuation upon being revved-up.
The light being on doesn't bother me and it has no noticable effect when driving down the highway but the problem is that it doesn't want to idle sometimes. It doesn't happen every time I stop but sometimes the idle gets so bad that it starts loping and will eventually cut off if I don't rev it up some. Last night, It actually started skipping when I pulled off from a stop light (first time it has done this!) The skipping cleared up quickly, but obviously what ever is wrong is getting worse!
Any help certainly appreciated!
Ernie
Ernie
