First off, sorry for another long post! I tend to get yappy.
Second, I apologize for asking such newbie questions, but in the long time that I have been here, I haven't paid much attention to 1st Gen suspension and driveline threads/posts. I have two 2nd Gens, so learning as much as I can about 1st Gens hasn't been a high priority to me. BUT, now I have one of my work Xs that needs some major help, and money has gotten so tight that my brother and I have to take care of it by ourselves to get it going again. Right now, I really need the help from some of you TTB driveline specialists!!
We finished up replacing the clutch on it late this afternoon (GD PITA), after messing with it when we could for a couple of days. The hope, and NEED, was to have it going by tomorrow morning, but after a test drive this evening, that ain't gonna happen.
Problems we observed: (btw, it is a '94 with auto hubs and 110K miles)
Movement in the wheel/hub assembly. When we had the front end in the air, we noticed you could wiggle the tire both side to side and up and down. This was more prevalent on the driver's side. With someone looking underneath, no movement in the balljoint/knuckle was observed, all of it seemed solid. All of the movement seemed to be in the wheel/hub.
Clicking noise while driving. During the test drive, a pretty constant, rotational clicking/slight clunking noise was observed. When I came off the skinny pedal, the noise seemed to go away. Tthe noise also sounded a bit louder on the driver's side. Sometimes it sounded like the tire sticker was still on, other times it sounded like a screw in the tire.
One auto-hub slips/clicks. Only put it in 4wd for a couple of minutes in the yard. When we got in a muddy spot with some upgrade, the driver's hub just spun and clicked. Obvious sign of bad hub.
Verification of bad hub. Pulled driver's wheel and auto hub "cap" off, and grease is everywhere. There is a seal, or o-ring, torn in two just hanging there. Looks like this seal should hold grease up in the "cap" end with the bearing, but that has let go and let the grease fly. Obvious sign of bad hub.
Try to help it a little. We pulled the c-clip off the shaft and remove the inner portion of the locking hub. The shaft end has some play in it, maybe 1/16". We remove the "key" and tighten the spindle nut a little. After another test drive, this helps a little, but all the problems are still there.
So, this is where we stand. We really need to fix this situation asap, can't have the truck down much longer........and if we don't fix it now, it won't get fixed until something major breaks. Obviously, we need to look into replacing one, or both, locking hubs. 4x4 strength and reliability is a high concern with this vehicle, so we may look into throwing autos back on (may have to work on Kris for a deal
). But for the wiggling stuff, how should we go about this? Can we remove the wheel bearings, repack them, and retorque the spindle nut for any improvement? Or are we looking at replacing the bearings? Is the fact that the axle shaft has some freeplay a concern?
One thing we would really like, is a pictorial breakdown of this frontend. If anyone has a CD and can get me a pic, that would be greatly appreciated.
Thanks for any help here guys!!!!
