rhuck60
- February 16, 2012
- DeQueen AR
- 91 Explorer
changing the multi-function switch will require pulling the steering wheel
but that is very minor work
remove the 2 phillips screws holding the wheel cover on
unplug and remove the wheel cover
remove the wheel retaining bolt and the counterweight
now you need a steering wheel puller or 2 short metric bolts to fit the 2 holes on either side of the retaining bolt
replace the retaining bolt finger tight and use a pry bar between that and each of the short side bolts
you can ease that wheel right off. thats how the puller works, actually
next remove the end plastic shroud ring by pulling the left side towards the door and then forward (stretch it out of round about 3/4 inch)
2 phillips screws hold the top and bottom column covers together
2 phillips screws are what hold the multifunction switch in place
