newbie to hella 500's | Ford Explorer Forums
fvumbaca
ct
98 ford sport
basically i got some hella 500's second hand and wired them very close to standard specs with a wiring kit that i baught the only differnece is that i have a 2A fuse as well as a 15A fuse in the wiring and its wired to the parking lights....the weird thing is that this setup has worked for me for the last 3 months no problem...but yesterday i went to firestone to get a new set of tires and now it doesnt work.....i checked the switch thats fine because it still lights up.....the relay is giving a clicking noise when i switch it on and off, i never noticed that before and i have multiple spare relays i tryed that on and all do it.....i blew the 2A fuse like 4 times but finally its not blowing any more....the 15 A fuse looked a little worped so i changed it for a new one for the hell of it and all the wire connects seem to be fine as well do all the grounds ....the only thing i can think of is that the wires are fried (but isnt that why the fuses are there i.e. protection from that ) or maybe the kit i baught has cheap wires and they finally went ....please help this has been driving me crazy for the last two nights
thanks
Have you checked the bulbs?
i checked the bulbs and everything seems to be in tack....i could understand if one blew but i dont think both would go at the same time.....alec did your X ever sell at the vw dealer?
Maybe one of the wires is shorting somewhere.
Splat disappeared after it sold on Ebay.
so do you suggest that i just buy new wirring maybe something thicker and start over??? what does the relay making that noise mean too?
Thanks
A clicking relay usually means it's working.
Get a test light, start somewhere, and work your way around to see where the fault is.
