Brandons
- May 20, 2002
- Ontario, Canada
- 06 F150 SC 5.4
I havent actually taken it out on the road yet.. part of the fact of no exhaust.... but i plan on taking it out tomorrow with or without. When i had the vacume line off it seems to go alright... But with it on, i get no drive unless i press the gas up to about 2500rpm, then it slowely moves. Without vacume line, engages after a couple seconds and then goes, or has a slight delay then clunks into gear. I do wonder if the vacume modulator is ok, it didnt seem that great when i was playin around with it. The TV spool was a bit of a pain to get out, had to do a bit of wiggling before it would come out.
On a bit of a side note, i usually got a CEL with the exhaust on,.. for the 10 minutes without exhaust on i happened to get no CEL at all...
Im also wondering.. i lost alot of fluid when i pulled out the TV spool.. i think i totally forgot to add more.. there was some on the dip stick when it was off (between the two holes), enough that i could get it off the ramps at least. I shall check that.
Another addition.... the fluid is still not see through this time (while in the 3" by 4" by 8" container).. only a week with new fluid and its already dark and opaque (non see through.. translucent is probably a better word for it).
