No Brakes | Ford Explorer Forums
No Brakes
teckpro
ford van
98 exp. XLT 2wd .
I had a rusted rear steel line that burst .
I had NO brakes , No front .
added more fluid to master cyl resinoir. and still after pumping no brakes in the front .
I replaced rear line ,bled . brakes apear to be fine.
I thought I would still have some braking in the front if the master cyl is divided/ has 2 lines from it, and a leak in the rear.
What would cause this?
T.
Air trapped in the ABS controller.
98 exp. XLT 2wd .
T.
Will air in the ABS system cause the ABS system to be triggered under normal braking?? Had this issue and wound up disconnecting one of my front ABS Sensors so I could drive.
Is air traped in the ABS after a rear brake line leak/brake typical ?
is that typical/ design flaw ??
Seems to me that defeats the purpose of having divided /dual wells in the master cyl.
