LaXplorer
- January 1, 2001
- Northern CT
- Explorer '91 XLT
I was on my way home from college about three hours away and after i had gotten home i went out to take my explorer somewhere and i had no clutch at all. It was very soft, and i could push it down with one finger. Furthermore when the clutch pedal was pushed to the ground i could not put it into any gear. When the car is turned off the clutch is still really easy to apply, but i can shift it into gears, and when i start it with it in gear it has trouble starting, but it will, than it will move, but i have no control over changing gears it is stuck in first, or reverse, i have not tried it in any other gear but i assume it would do the saem thing. The clutch does not affect anything, and is still soft. I can not take it out of gear eatherwhen i start it in gear, the only way to stop it is to shut off the car. I have a '91 xlt with about 180000 miles on it, and the clutch was replaced about 2 years ago........I hope all this makes sence, and i hope that someone out there can give me some advice.
Thanks,
Vic
Thanks,
Vic
