budwich
- May 4, 2005
- Ottawa, Ont
- 96 XL
now that you have checked / fixed your voltage levels from your battery and along the way (inertia switch), you need to determine whether your fuel pump relay is operating and if your PCM relay is staying operated. If your PCM relay is "clicking", that is your problem. If your PCM relay is operated "solidly", then you need to check the operation of the fuel pump relay ... as mentioned, key off key on (no starting)... let it run til the PCM drops the fuel pump relay... you should "see" this from a "loss of ground" on the LB/O wire going to the fuel pump relay (the PCM grounds this wire to operate the fuel pump relay and when it wants to stop the pump, it removes the ground...as stated earlier, if the PCM determines that the truck ain't starting ... in this "test", you aren't going to "start"... just key on... then after a few seconds, it drops the ground). You want to test this very clearly. If this succeeds, then the system, PCM, fuel pump, fuel relay are doing their jobs and as a result you can then look a bit further.... crank sensor which tells the PCM that the truck is "starting".
