gavin
- September 27, 2002
- Anchorage, Alaska
- '97 Explorer XLT AWD 5.0L
Posted this in my build'ish thread, but thought it might be better to create a new thread.
Finally got around to doing some more work on my 86 B2 yesterday, but having a couple issues.
First, it will not run off the alternator. The battery that was in it died, since the truck had been sitting for ~9 years. I did start it up once a few years ago, but had to leave the jumper cables up. Soon as I disconnect, the truck died.
It should be able to run without a battery, no? I took the battery out a couple weeks ago, and yesterday we just had the cables hooked up directly to the truck's wires.
Secondly, the fuel pump ain't coming on when key is turned to On/Run. The relay is clicking, but no juice is getting to the pump apparently.
Run a jump from pos to the pos terminal on the inline pump, it runs.
Inertia switch doesn't appear to be tripped. Maybe it went bad with enough moisture?
The interior of the truck is quite... moist.
The foam cusion on the firewall is soaked; a little squeeze and water was dribbling out. Possible the moisture killed the inertia switch, maybe?
