Willard
- March 16, 2007
- Bloomington, Indiana
- 04 Ranger Edge
So I was driving along today like normal, mid throttle, and my explorer goes to shift into third gear and something popped.
I lost forward gear, so I coasted into a driveway. It went into reverse for a second or two, then nothing. This whole time it's making a nasty whirring noise. It makes the noise in any gear, park and neutral included.
I haven't really done any diagnostics yet, I was too mad to deal with it. The first thing I will do is pull off a cooler line to see if the pump is pumping. If it is, I'm guessing I lost the torque converter. The truck won't move in 4x4, so the transfer case isn't the issue. I also assume this since it makes noise in park and neutral.
I rebuilt the transmission myself about 20k or so ago, but the torque converter and pump were not touched, leading me to believe one has failed. The noise sounds like it might be the torque converter, although I have no idea. Everything was working beautifully before this. The truck has about 240k on the odometer.
Any ideas would be appreciated.
Edit: Forgot to add, fluid level and condition was good, and there are no leaks.
