No Glove Box Light | Ford Explorer Forums
No Glove Box Light
Larry Swanger
So I bought a 2013 Explorer XLT and the first time I drove it after dark my wife opens the glove box and can't see a thing. No light. Also have problems with the map reading light by the rear view mirror.
Call the salesman who drives an identical vehicle and schedule an appointment for repairs. Meantime get on the Ford Parts website to check on the glove box light and come back "nothing listed for your vehicle".
Now I can't recall having a vehicle for years that didn't come with a lighted glove box.
Say it ain't so.
Say it ain't so.
Yeah, I never noticed a glovebox light either. Although what I do notice is that I have a center console light and my Fusion has a lit center console bin. Those are the only lights I really notice for compartments.
Say it ain't so.
Welcome to the Forum Larry Swanger.:wavey:
Perhaps you have to move all the way up to Limited to get that little bulb.
I also went to the fordparts.com website and came up with 'No Data' for the XLT but when I searched on the Limited it came up with part #14413, $23.16.
I know it doesn't make much sense but my 2011 Limited has the glove box light. The picture shows where the switch is mounted.
Thanks for the quick replies. I was going to check out the Lincoln Navigator too see but this will save me time.
As a side note my buddy has a 2013 F-150 King Ranch and even it does not have a light in the glove box.
Larry
One question: Is that part number for just the bulb or the complete kit?
Larry
Looks like Ford is really cutting back on costs. I still like to carry one f those small LED flashlights in any case. Good luck Larry and happy motoring.:thumbsup:
Does anyone know if the plug is there to hook it up or will we have to hard wire it in? I plan on getting this as I also have an XLT and find it frustrating that there is no light in the glove box!
Our Sport with 402a has a glovebox light. So surely some XLTs have them as well?
My Sport with 400A does NOT have a glove box light. For those that have one, where is the bulb mounted?
This is starting to make me feel like Ford is cheaping it up now days.
Get a flashlight.........
I stopped into the service department at the Ford dealer for a minor fix and had them check to see if I could get the light put in. They told me it would require a different wiring harness. Big bucks. Ain't worth it.
our sport has one. 402a package. already swapped it for LED!
It seems to part of the switch itself.
Who isn't? I remember a similar level of sadness when they quit putting lights next to the visor mirrors in Contours.
This rates slightly below that on my list of things to care about.
Here's a solution that is cheap and versatile;
HAHA! 2 of the cheep ones like that and a 3 D-cell Maglight in in the glove box in mine already and I have a Limited with the factory light.
That switch is what was causing my glovebox to rattle. You might be better without the light lol.
It turns out this project is perfectly doable. I can recommend it to anyone who doesn't have a light in their glove box and don't want to go the flashlight route. It'll take you an hour. My 2012 XLT didn't have the glove box light, but there's a clear spot for where it's supposed to be, which is the top left corner of the glove box, as there's a plastic thing there covering the hole where the light would be.
(To "drop down the glove box, open it, then on the right side pull on the string and pop it out of the hole. Then feel around just under the storage area on the "felt" for two plastic things that you push up as you pull the glove box down. Then the whole thing will pop down).
I didn't take a picture of where it goes but here's the plastic thing that would've been the glove box light if I had one. It pops out from behind by pushing on the two flaps.
Now you order one of these (at least for 2011-2015, not sure on the 2016+ explorers what they use). Cost ~$15.
But do note, there's no wire in that package, the packaging is a lie! I'm not sure if there is one normally but even on Fordparts I don't see a wire. I think it's part of a different harness, which I don't have.
So, for the wiring, the back of the glove box light connector has 2 pins, + and - (order doesn't matter, but I put - on the left, + on the right).
(If someone knows what connector one could get that fits onto those pins, please post it here, I'd rather put on a real connector than a makeshift wiring).
To hook the wires to the pins I used standard crimp connectors (there's better connectors out there, so do check what your store has), but as they're too big to fit in there, I squeezed it together from the sides to get this:
Then I shrink tubed it so that if those two connectors meet, there's no short circuit (you could use electrical tape as well, or solder the wires and put silicon on top, lots of solutions). Squeeze them onto the pins (careful, those pins are not that "tough"). They should be on pretty snugly against the plastic sides.
There are wires behind the glove box that might be worth checking, but I really didn't feel like hunting for a 12V when I did this today, so for 12V non-switched (you want the light to work even if car is off), the easiest for me was to take 12V power + ground from the cigarette lighter in the front of the middle console. I used "posi-taps" but any wire tap will do. To get to that area you have to get into the back of the center console to get to the 12V outlet. If someone doesn't know how to get back there, I'll put instructions at the bottom of the post.
Once the light is wired, plop it in to the socket on the glove box and pull the wires from the light up behind to the left, and you'll enter the back of the console/radio area. Do the tap there. The distance is really short so the wires don't have to be long. (As always when installing lights etc, do the ground wire tap first)
A quick test shows that the wiring worked:
But the default light bulb is pretty bad though, so I put a LED in. Much better:
Put everything back together and test it some more, here the pin is out (open state, I'm just resting my beat up finger on it)
Here the pin is pushed, light goes out.
A nicer connector would've made this job "feel better", but what I did works fine.
To remove the center console to get at the back of the 12V:
First put the car in neutral (the shifter has to be in the middle to get the console out). Kill the ignition (you won't be able to remove the key) and cut the power by removing the negative terminal on the battery. Pull off the side panels next to the radio / sync screen (toward you), then pull off the side panels next to the console on both sides out a bit (black ones usually). You don't have to remove them completely, just pop them out an inch or so. Pull off the back panel in the storage compartment by pulling it backwards, then remove the bolt that you see there next to the 12V in there, facing up. Now grab the whole center console area and yank it back and up carefully. You have to unclip a cable that hooks to the drive mode before you can pull it up a bit higher. After that I highly recommend removing the gear shift knob so that the whole panel can come out (2 screws on the front side and a wire that unclips). If you don't want to do that, you can at this point pull it forward enough that you can access the 12V and tap the wires that you pulled in earlier.
Just curious. Are there still some 2016+ trims that do not have the glove box light?:dunno:
Say it ain't so.
Only ford my GMC Terrain had a lot of lights and cubby holes for stuff.
