Ok... I am sorry about sending you to the "blender door problem"..... of course, there needs to be more trouble shooting to eliminate other things. So first off, ensure that your temperature setting is in the red only on your controls. Choose venting that is only to your feet. This ensures that air conditioning is not working as some setting actuate both (ie. "head and foot", and defog). Anyways, next check to see if you air condition compressor is on (ie. clutch has operated). If it has, then there is another problem cause it shouldn't be on. If it is off and you are still getting cool, then it is likely only outside air and it is not being heated. It is then likely that your heater water valve is not operated for some reason. It is vacuum operated (I think... if I remember right). ... need more info on symptoms / observations. Hope it helps you further.
