No Power for Lo-Beam Headlight | Ford Explorer Forums
bonesy
DC
1996 5.0L Eddie Bauer
Just the other day I noticed that my driver side headlight was not working and I replaced the bulbs. However with the new bulbs the lo-beam still was not working. I pulled out the voltmeter and the lo-beam wire was providing no power. How can I reestablish power in driver side low beam wire?
Is there a separate fuse or a relay (position?) that I can check for a loose fitting?
Thanks.
you have a LOM problem. Lots of posts... some bypass some fix... take your pick.
LOM = Lamp Out Module. It's in the center console.
wow. that was one of the easiest repairs i have made to date. Removed the LOM, resoldered the infamous pin (i believe pin 10 on the connector), plugged it back in a worked. repair time 5 mins.
thank you. thank you for your guidance.
and you saved $70 for the part, plus labor !
