burrsj2002
- January 25, 2023
- Hereford
- 2015 Explorer 4WD
The turn signal lights do not work. However, the head lights and hazard lights do work. We took the following actions:
1. Fuses.
• Checked under hood fuses. Found no blown fuses. Checked the terminals and found voltage across the tongs.
• Checked fuses inside cabin. Found no blown fuses. In addition, changed the fuse controlling lights anyway.
2. Signal Flasher.
• Changed signal flasher relay, twice. One part from AutoZone and one part from O’Reilly.
• Checked tongs for the relay and found voltage across the tongs.
• Note: The hazard flashers work on the four lights, two front and two rear.
3. Combination Switch (Headlights and Turn Signal).
• Tested switch: headlights, low and high beams, work. Turn signal does not work but hazard lights do not work.
• Change the combination switch.
4. Hazard Switch.
• Tested the flasher and found all signal lights work.
• Changed the switch anyway.
1. Fuses.
2. Signal Flasher.
4. Hazard Switch.
