yorktown1
- May 15, 2006
- Yorktown, VA
- '94 XLT
I have a '94 XLT that had intermittent starting problems last year. On an infrequent and random basis the engine would crank fine but doesn't catch. After wiggling the wires and tapping on the fuel tank it would start, but eventually I was told the fuel pump was failing. I knew it was 12 years old so I had it replaced and everything's OK for eight months, but now the same problem is occuring. When it's working, you can hear the whine of the fuel pump when the key is turned. When it's not, no whine so I don't think the fuel pump is getting power. Once the engine is running I've never had any problems, so I'm not sure it ever was a fuel pump problem. Sometimes it won't start, then after sitting for an hour it will. Any suggestions?
