No R/H Signal / Brake Light | Ford Explorer Forums
03Explorer4x4
Ontario, Canada
2003 ford explorer sport 2 dr.
Right rear signal brake light out , Pulled assembly checked bulb ok
tested with test light no brake or signal , Right front signal blinks super fast and so does bulb in dash for R/H only. Left hand front and rear work as they should. I suspect broken corroded wire probably in fram, but before I start my hunt I was wondering are there any known problem areas in the chassis were wires rub? does anyone have a wiring diagram I could take a quick look at
thanks in advance Dave
