No REVERSE | Ford Explorer Forums
No REVERSE
onlyworth10
Trenton,GA
2000 XLS
I just installed my rebuilt valve body from central valve bodies, filled her back up with fluid, started it up put in reverse and its goes forward? all the gears go forward even park...and neutral.... Guys any help would be great... IM stumped...
HMMMMM I LL have to go back under tommorow.... But I dont think I did....
I didn't realize that you have a 5R55E. I thought that it was an A4LD. My mistake. You don't have a Z link on the 5R55E. It's possible that the linkage isn't connected either internally or externally.
Pics of this so called linkage? It was getting dark and couldnt see to well.
The picture was on the first page in that link.
Now would I havent unhooked the linkage during the Vb removal? Will be going back under today...The old vb gasket was destroyed so I hope this does the trick.
No Movement at all
I replaced my VB with a Remand one from CVB, Got it all back together and Now she want move a inch, forward or back... Any thoughts..... Its a 5R55E
This is weird, I just went out and started it, and put it in R and It actually went in reverse and moved about 10 ft then stopped.. Im bout ready to burn it... Any Help
