itscody
- December 31, 2010
OK, played with my '02 when I got home last night, by turning the cluster rheostat full down past the detent you can in fact turn off all interior lights even when you open the door(s) but with the rheostat full off you can still turn on map/dome lights with the little button at the lights. Also if your dimmer was fulll dim or off your instrument cluster would be dark with the headlights on.
Here is one I had in a mustang years ago, the fault was in the power "behind" the fuse box. In other words the fuse was good but there was no actual power coming into that fuse or component of the fuse box. I had to remove the fuse box from it's mount, turn it around (difficult as most wiring harnesses are very short) and re-attach the wire to the box.
I would get your lite tester or voltmeter and ensure that your fuse for that section is in fact hot. Your fuse could be "good" because there is no power to burn it up. Re-reading what you replied to waskly I'm not sure if you visually checked only the fuse or the contacts for power?
I would go as far "upstream" in this process as possible to see where you have power. Ensure there is power in the slot at the fuse box.
Good luck, electrical failures are tough, there's no fluids or traces of the problem generally.
I sure up there will be no fluids in a eletrical problem lol, And ill try messing with things on the dash but i cant cant the lights to turn on by opening doors, Pushing buttons or nothing and when i try testing the power to the lights plugs there not hot so looks like ill have to see if the fuse is even getting power, Ill try that and then you know.
