xhauler
- November 10, 2016
- Idaho
- 2017 Explorer Platinum
Hi all, this is my first post.
On Halloween night, we bought our new 2017 Platinum. Drove it home and pulled in the garage and shut off the engine. Then I pressed the on button so I could look at all of the menu's in sync3 and learn the system. So with the engine off and car on, there is a noticeable white noise coming out of the lower front door speakers. As I was turning things off and on, to determine what effected it, I found that it is related to the center console display briteness setting.
This is what I've determined so far:
- when the display setting is on Night to makes the sound
- when the display is set to Day and the brightness is full = no sound, less than full makes a sound, it is easy to heard when on this setting because you can just slide the setting with your finger back and forth and make the sound go on and off
- if you press the off button (which leaves the screen and stereo on) there is no sound
I went back to the dealer the next day and showed them the sound. We went to another Platinum and was able to reproduce the exact same thing. They said they would have to put it in the shop and work with Ford engineers to figure out what was going on. I asked them to debug with the other Platinum and that is what they are doing. 10 days later and they still haven't found anything.
Can anyone else reproduce this issue? I think it has to do with the new Sync3 system, not sure if it is only Platinum or if the other trims also do it.
Thanks!
Thanks!
