ErnestJ
- November 26, 2013
- Grandview, Missouri
- 2000 F-350 SD 4WD
2002 Explorer XLT. Air temperature changes correctly but location does not. The door behind the center vents has vacuum actuators on both ends of the shaft. The connections are broken on both ends of the shaft. Is this the mode door? Is this a common problem? Shall I start pulling the dashboard? Help.?!
