Noticed water from the tailpipe | Ford Explorer Forums
elitecloud
Maricopa, AZ
98 EB
havn't heard anything out of the ordinary comming from the engine, i will be doing an oil change in the next week tho
what ailments would cause water dripping from the tailpipe and should i be conserned
thanks
Might just be some nasty old byproducts like condedsation. Is it just when you start it up? Do you do mostly short drives. Water out the exhaust pipe Hmmm sounds like you could use an exhaust grounding strap. Opps forget that last sentence. On a more serious note, do check your oil for any foaming and or discoloration. Might want to check your plugs also. I bet that water goes away after riding for awhile. Welcome
By the way, I think every car/truck I've ever owned did the same thing.
a amount of clear water driping is 100% normal. now if its colored or has a bad smell. then i'd start investagting. otherwise its nothing to worry about at all.
With heat comes moisture. Water is fine.
its one of the byproducts of combustion and then the catayltic converter produces CO2 and H2O
I second everyone elses opinion! :thumbsup:
-Drew
10-4 guys
i'll check for any admoralities in the water
