Koichi
- May 14, 2013
- Yokohama
- 2000 xls RHD
Hi from Japan
I have 00y Explorer XLS with RHD:exp:
I need your help! I'm looking for O ring seal for fuel injector line.
Few days ago, I had to try to replace thermostat hausing because of coolant leak and cut off a fuel line near the thermostat.
After connected the line, I found the gas leak from that point and the O ring seal went bad.
It is a seal between Fuel Injector Line Part#9E964 and Fuel Injection Supply Manifold #9D280.
The O rings size are 7.5mmID , 3.6mmW with green/dark green color.
Anyone could you tell me the part number?
Thanks, Koichi
Thanks, Koichi
