watisgood
- March 19, 2007
- LoNg IsLaNd
- 1997 ford explorer sport
Some help would be great...Thanks
Hey Guys,
I threw a check engine light the other day and received the following codes:
P0171
The PCM has determined that during testing, the fuel system for bank 1 was tgoo lean. (Bank 1 identified the location of cylinder #1, while bank 2 identifies the cylinders on the opposite bank)
Definition- Fuel trim bank one condition
Explanation- The powertrain control module uses the oxygen sensor to calculate the air/fuel ration of the engine. The computer has recognized a rich or lean condition on one engine bank only.
Probable Cause
1. If bank one and two codes set together suspect fuel pressure or MAF (Mass Air Flow) Sensor
2. Oxygen sensor defective
3. Ignition misfire-repair
4. Fuel injector problem
P0442
The PCM has determined that a small leak exists in the evaporative emission control system.
Definition- EVAP small leak/no flow condition
Explanation- The evaporative emission system is monitored
Probable Cause
1. Defective or loose fuel cap
2. EVAP canister or hose cracked-not connected
3. Purge or vent solenoid defective
4. Vacuum leak at engine
P0442
Definition-EVAP small leak/no flow condition
Probable Cause
2. EVAP canister or hose cracked - not connected
Any ideas where to start?
Hey Guys,
P0171
Probable Cause
P0442
Probable Cause
P0442
Probable Cause
