ERUSH97XLT
- October 9, 2008
- Omaha, NE
- 01 XLT, 03 XLT, 13 XLT
Hello,
I have a strange event with my cooling system:
I just replaced the water pump and thermostat. After doing so, I flushed the cooling system and refilled with fresh coolant as well as burped the system.
So, here's the odd part: my temperature gauge fluctuates with a predicatable frequency (it's not random). The instant I attain normal operating temperature, my gauge drops way down to cool, then warms up again slowly. In essence, it "warms up", then "cools down" in about three seconds, then "warms up" again in about ten seconds.
I got freaked out the first time this happened, so I stopped the car when the gauge read cool, opened the hood, and my upper radiator hose was pinched shut!! I opened the radiator cap to release the vacuum and filled the radiator. This keeps happening; whenever I park, I wait for the gauge to drop to cool, then release the vacuum and refill with coolant. Each time this happens, I use less and less coolant to fil the radiator. Another odd part: the radiator isn't drawing coolant from the reservoir.
Any thoughts as to what the *%^&#*$( is going on? Should the radiator cap be replaced? I hope I don't blow a hose while driving due to the intense vacuum. . .
I should also note that I installed the thermostat in the correct orientation, and it does not have a air hole (neither did the stock one).
Thanks for the help,
ERUSH
ERUSH
