hoss_hanna
- July 31, 2009
- ft. smith, ar
- 91 4x4, 93 XL, 01 mountie
:roll: my 91 4x4 ex has developed an odd problem... died flat out on the way home from a camping trip, checked fuel fire and air had no fire. after about 20 min had fire again a cupla miles later nothing, 20 min later fired up again few miles later same issue limped it almost home in this fashion. figured i needed a new coil pack so i grabbed a spare i had and replaced the one on the truck. fired it up, started on the first bump of the key, idle was smooth gave it a bit of gas and it started missing bad backfired a few times and died. so i hooked up a timing light started it up and idle was fine then it went nuts thing flashed like a strobe set to random, thinking it might be the ignition control module or pcm any ideas? i have a 93 parts truck 2wd would the pcm or icm work outta it? my truck is auto tranny with manual 4x4 shift.
PS. sitting on the side of the road in summer with a truck load of camping gear 3 kids a wife and a dog is NO fun
