Yes the MOOG cams are stamped with 4x4 3 degrees and 4x2 3.5 degrees, but I've heard that 3 degrees is impossible on a 4x4, and that max is 2.75 degrees no matter what the cam states. I thought the 2" pivot brackets would be just right, too. It seems somewhere in between stock and the 2" drop brackets would do it, which would mean modifying the stock or drop units if the 2.75 (or 3) degree cams will not do the job.
