Oil filter adapter. | Ford Explorer Forums
Oil filter adapter.
bigdo182
magnolia.ohio
93 xlt
hi everybody,old guy from ohio here,has anyone in here ever changed a oil filter housing adapter, i got one leaking and need to change o rings in it
Welcome to the forum! Check out the 91-94 Explorer Section. I know they will be able to give you an answer.
Its a really tight fit in there.. IIRC you will have to pull the exhuast (I think) and possibly lift the motor some to get it past the frme to get that center bolt out...
Last time I had it off was during the engine rebuild and the motor was out then.
I've got a good shot of where it is on the engine if you need it..
~Mark
