divot
- December 6, 2009
I own a 2003 exp. with 70k. it has developed a severe oil leak. which i though was rear main seal. I have replaced the seal with the upgraded seal w/ wear sleave twice in two months. something is still leaking oil between trans. and engine. I am not convinced it is rear main. could i be overlooking something simple. there is no oil anywhere else on the engine. it drips out between trans and engine. And it is oil not trans fluid. I have also replaced valve cover and plenum gaskets. Please help. I do not want too remove this engine AGAIN unless i know it's not going to leak. Thanks so much.
