swhite005
- May 26, 2005
- Huntington Beach, CA
- 91 Eddie Bauer
1991 Explorer Eddie Bauer 4X4 4.0L...
Took it in for an oil change at FORD and they told me they think the oil pan gasket needs to be replaced. No tests were done to prove this, but there is some oil dripping and visible oil on the outside bottom of the oil pan. I was looking at the engine today and noticed what appeared to be fresh oil leaking from the valve cover closest to the engine block (driver's side). I can't actually see the oil dripping, but it is definitely "wet" looking and doesn't appear to be old spilled oil. The closer I look, it appears the oil is possibly leaking onto the components below and then dripping off the oil pan. I'm not able to see the oil pan gasket very well to determine if it is leaking as well. Since there is visible oil coming out of the valve cover gasket, do you think I should start by replacing that gasket? Also, does that gasket have to be purchased through FORD or is an aftermarket gasket through an auto parts store going to be okay? Thanks
