mysticclam
Typo King
- April 2, 2004
- Tacoma, WA
- 91 XLT
Ever since my 2 inch skyjacker lift and 33s, my truck has not driven well. I didnt expect it to be as good as before but once you get to speed you are constantly fighting to keep it in a straight line. It will pull to one side for awhile then suddenly pull hard the other way. Anything above 55 is too scary. Ive had it to Les Schwab a bunch of times and it never gets right. Ball joints and Wheel bearings are good according to them. Everything was in spec except for cross camber. That was a while ago but not many miles ago. I have tried a completly different set of tires and get the same exact thing. I measured some stuff today and the distance between the front and rear wheel center is longer by about 1.25 inches on the passenger side. Also, it seems to be toe-out by about 5/8 inch. I cant measure caster but it is visibly positive. It drove straight before I did the lift. Also, I have the oversized Camber Bushings in for the camber. I beleive they are 2.75 degrees. Im going to look for play in the tire rod ends. Also, one shop told me the drag link was worn where it connects to the pitman arm and when I took it to another shop near work to get it replaced, they said it was fine and didnt replace it. Im thinking of just replacing it to see if it helps. Maybe the tire rod ends too. Is the drag link supped to have a slight bend at one end?
