Only defrost Vacuum leak | Ford Explorer Forums
Chris5547
Fargo, ND
Ranger XLT
I had my vents default to defrost and floor. I went looking for a vacuum leak and found my fuel damper was leaking into the vacuum reservoir. So I replaced the fuel damper. Vents still didn't change. I then replaced the vacuum reservoir thinking the amount of gas that got in it is causing problems. Still no changes vents only come out the defrost and floor. Is it likely I have another vacuum leak or could there be fuel in the line somewhere still causing my issue. I have check the vacuum lines as best as possible without ripping everything apart. Thoughts?
Welcome to the Forum Chris.:wave:
What year is your Ranger? This Forum is for the 2011+ 5th generation Explorers.
2000 Ranger XLT , sorry about that
