hawgx2
- July 29, 2004
- roy ut
- 91 mazda navajo
91 mazda navajo koeo codes are fine (11) koer code is 42 (o2 sensor) which I have replaced along with the fuel pump,fuel regulator, relay (all 3). I have checked all the fuses and every other sensor, and the injectors all seem to be ticking. The wire from the o2 sensor to the pcm has got good continuity but only reads .002 volts and does not switch . I believe the computer is running the 4.0 in an open fuel loop. I have also cleaned the mass sensor. I am going broke fixing things that are not broke can anyone help me PLEASE.
Thanks in advance
Thanks in advance
