Lew34
- November 29, 2007
- Richland Center, WI
- '93 XLT
93 explorer with a replacement plastic fuel tank. Previous owner states the gauge worked ok for a time after the replacement. Now with the key on, gauge goes to overfull. I suspect it indicates an open in the circuit. Need to know the physical location of the sending unit ground connection. For now I just reset the trip indicator each time I fill up and then fill up again after 200 miles. If I cannot cure this problem without dropping the tank I will just live with it since I only use the vehicle to do local errands and dropping the tank and it associated skid plate and heat shields looks like more work than I care to do. I realize this problem may already be addressed somewhere else on this site but as a newcomer and on slow dialup (24K at best), I couldn't find anything.
