ck1938
- May 20, 2006
- Redmond, WA
- 1991 XLT
My 91 Explorer XLT almost always gets hot when driving in town. I can drive hours on the highway non-stop or let it idle for an hour and it won't heat up. But if I spend 5 minutes going from stop light to stop light the temperature indicator starts getting above the L in Normal and the air conditioning gets hot. I've done a few things:
1. Replaced the thermostat - no luck
2. Tampered with the fan clutch so it is always going - no luck
3. Removed the thermostat - no luck
4. Flushed the cooling system - no luck, the water just boiled over and overflowed the reservoir
I just saw a post about checking the lower hose so I will try switching that out next. Any other ideas? The radiator is new, or so the previous owner told me. Water pump maybe? Any advice would be appreciated
