niteklub79
- June 12, 2009
- CORPUS CHRISTI
- 1993 base auto 2wd
Hello All,
I was driving to work this morning when i started to hear a scraping/sucking noise from the front end...My thermostat read as though the truck was overheating, so I turned the truck off and attempted to figure out the problem...
Upon inspecting the engine compartment, I noticed that my coolant reservoir was filled to the brim and leaking...I then turned the truck back on to see what the problem could be...
The coolant slowly drained out of the reservoir and I figured all was well, then after a few minutes of driving, the temp gauge started to climb again. I suspect that this is a thermostat issue, since my temp gauge hadn't been climbing above the 'R' in NORMAL over the last week. Another strange aside was that my heat, which never worked before, is now working...
I'm thinking a system flush and a new thermostat, any suggestions/feedback?
