- June 17, 2004
- Knoxville, TN
- 98 Limited AWD 302
Ditto, look closely at the whole cooling system. Make sure that all of the electric fan components are working properly. I would change the thermostat for sure. I suggest not buying a normal "fails closed" thermostat.
I have had my own cooling issues, twice in the last two weeks. I have an electric fan which had a circuit breaker fail two years ago, and last Wednesday the trigger wire came loose.
I have used a Failsafe thermostat since I bought the truck, so three times the thermostats have ended up locked open. That means that my truck was drivable after the overheating, though it ran very cold. Motorad is the original maker of this thermostat, now it comes under the brand of Murray, but still should be named Failsafe. I've bought these from O'Reilly's, for a SOHC it's a part # 7248-192.
Check your coolant, the level and freeze rating. Add Water Weter to make it cool/heat better, check it often just after opening the system and cap.
Electric fans are great when they work, but it must be stone cold reliable. Be sure that the controlling parts are of the highest quality etc. Regards,
