Broncolover
- April 4, 2004
- Douglasville, Ga.
- 2000 Limited Explorer
2000 Ford Explorer Limited 4.0 SOHC
I have a crazy problem.. Here goes... In traffic w/ AC running the truck will quickly overheat... without the ac on it steadily climbs and gets to hot. The truck temp gauge just teeters on the line of being hot, but not actually boiling over. It gets to the point where the ac stops blowing cold. O.k. in the past week I tried several things to no avail.
First I replaced fan clutch.. didnt work... took the clutch back and got another... still didnt help....
Well Then I bought a waterpump and just went at it and replaced the water pump.... didnt help. Before doing the Pump, I went ahead and flushed the system out with my garden hose hooked up to my prestone flush system I have installed in the heater hose. I flush/Fill every year.
Today I replaced the thermostat with Napa brand 192 degree Stat and took it for a test drive and it still is overheating. Some could say air in the system? after the thermo and after the water pump fiasco? I dunno? I ran the heat on full blast for the 15 minute ride back from the thermostat test run. It has been really hot here in Atlanta... the other day the temp gauge for outside air was showing 104 degrees.... The truck was running hot and I had the freaking heat running to cool it down... that sucked in Atlanta traffic!\
Any Ideas? I am by no means a master mechanic... I'm still learning.
