deamon3
- July 27, 2008
- Wisconsin
- 94 Eddie Bauer
From what I've found out this is a common problem for the transmission to overheat and spray out all it's fluid in one big dump.
Basically mine does exactly this. I've read that the most common problem is a clogged radiator , or a clogged transmission cooler. Now I'm going to have to have it taken in to get looked at , is there any other common cause for this or are those two most likely?
It does it if it's really hot outside and I drive too fast or rev it too high. I always have to stay under 1500-2000rpm and that in turn means driving very slowly. In winter , it doesn't leak a drop , only when it's hot out.
